alignment ?
Old Dec 5, 2003 | 08:31 PM
JPineda's Avatar
JPineda
Default alignment ?
I just ordered some Koni yellows for my integra. I plan on installing the shocks on my car as well as new springs at the same time. How long should it take for my springs to break in? When should I get an alignment? By the way, the springs I will use are Skunk2 coilovers.
Old Dec 5, 2003 | 08:45 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Any quality spring such as Skunk2 does not break in. So as soon as you get them on go get an alignment h:
Old Dec 5, 2003 | 10:25 PM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
give it at least 2 weeks so the springs can settle in then go ahead n alignment it
Old Dec 5, 2003 | 10:55 PM
Spec R's Avatar
Spec R
before u align it, have someone measure the distance between the center of your wheel to your fender. The rears should be the same to each other, and the fronts should be even with each other, but not all four have to be even. Even though this is a crude adjustment, its better to have your heights even to the best of your abilities before u bring it in to get aligned.
DB Squad
Integra Forum Moderator
Old Dec 5, 2003 | 11:02 PM
Optiblue's Avatar
Optiblue
what kind of drop are you getting? race or sport? if you're getting a sport drop "nothing lower than 1.75inches" then you should be okay w/o an allignment.... if you go lower than 2 inches... I suggest you get a camberkit before you get your alignment done...
Old Dec 6, 2003 | 12:37 AM
JPineda's Avatar
JPineda
I've already got a camber kit and my car is actually currently aligned right now. It's just that I'm going with a new set of springs and new shocks and figured I'd need a new alignment.
Old Dec 6, 2003 | 12:34 PM
g2tegls's Avatar
g2tegls
MR, ftw
I'm pretty sure you will need an alignment, even if camber "looks" okay, because other things get all f'ed up like toe.
