ITR Rear hub
Are the JDM CTR and the USDM ITR rear hubs the same ???
Reason I ask is that I need a rear hub for a 98 CTR and cannot find one, so I was wondering if the US ITR hub is the same.
Thanks
Thanks
Rear hubs? Do you mean the rear disk assembly? I would assume the ITR 5-lug setup would be the same, but I can't say for sure.
took the rear 4-lug setup off one of my GS-R trailing arms and swapped it onto one of my old drum trailing arms (1 big 24mm bolt and 4 torq bolts) because the GS-R arm was bent. I'd image the Type R suspension/brake stuff works the same way.
