Installing an alarm into a 5th gen civic coupe !
Old Dec 1, 2003 | 09:40 AM
honura's Avatar
honura
Seni
Default Installing an alarm into a 5th gen civic coupe !
I have a 95 coupe and I wanna install an after market alarm can someone tell me where I can find a wiring schematic for wiring an alarm ? Thanks !
Old Dec 3, 2003 | 10:37 AM
billscivic00's Avatar
billscivic00
1992 - 1995 civic (i know this will work for a 1992 civic, should work up to 1995, but not sure)
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |brn conn abv fusebox |
| STARTER|black/white |+ |brn conn abv fusebox |
| IGNITION|black/yellow |+ |brn conn abv fusebox |
| ACCESSORY|yellow |+ |brn conn abv fusebox |
| POWER LOCK|green/white |- |in drivers door *2 |
| POWER UNLOCK|green/red |- |in drivers door *2 |
| PARKING LIGHTS +|red/black | |grn plug top of f-box |
| PARKING LIGHTS -|white/black | |anti-theft module *3 |
| HEADLIGHTS|red/white (low only)|+ |steering column |
| DOOR TRIGGER|lt green/red |- |driver kick panel |
| TRUNK/HATCH PIN|grn/blk 2 silv dots |- |blu conn above fusebox |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| TACHOMETER|blue *1 | |2-pin plug near distr. |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|blue/green *4 |- |steering column |
| WIPERS|blu(low),blu/yel(hi)|- |wiper switch |
| LF WINDOW UP/DN|red/yel - red/blu |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|grn/yel - green |A |in drivers door or dkp |
| RR WINDOW UP/DN|yellow - yel/grn |A |in drivers door or dkp |
Notes:
*1 Also at round gray connector next to hood strut.
*2 Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
*3 the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
*4 can also be found blue/red at anti-theft if equipped
1996-1999 civic
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY|white/black |+ |ignition harness |
| POWER LOCK|green/white |- |blue plug dkp or *2 |
| POWER UNLOCK|green/orange*3 |- |blue plug dkp or *2 |
| PARKING LIGHTS +|red/black | |dkp/fuse box or *4 |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|red/wht(L)red/blu(H)|+ |steering column |
| DOOR TRIGGER|lt. green/red*5 |- |factory alarm plug*2 |
| TRUNK/HATCH PIN|blue/blk*6 |- |dkp, harness to rear
*1 Drivers side fire wall under hood.
*2 Factory alarm plug located behind radio. (green/plug).
*3 Can also use blue/yellow for driver door unlock only.
*4 Male blade terminal at fuse box. Also at the back of the dimmer switch.
1999-2000 civic
| STARTER|black/white |+ |ignition harness or *1 |
| POWER LOCK|green/white |- |keyless entry module *2 |
| POWER UNLOCK|green/orange |- |keyless entry module *2 |
| LOCK MOTOR|white/red | |drivers kick panel |
| UNLOCK MOTOR|blue/red | |drivers kick panel |
| DISARM DEFEAT|yellow/red | |keyless entry module *2 |
| PARKING LIGHTS +|red/black | |keyless entry module *2 |
| HEADLIGHTS| | | |
| DOOR TRIGGER|lt. green/red |- |OEM alarm plug *3 |
| DOME SUPERVISION|same as doors | | |
| TRUNK/HATCH PIN|blue/black |- |OEM alarm plug *3 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE| | | |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray |- |OEM alarm plug *3 |
| WIPERS| | | |
| LF WINDOW UP/DN|red/yel - red/blu |A |drivers door switch |
| RF WINDOW UP/DN|blu/yel - blu/org |A |drivers kick panel |
| LR WINDOW UP/DN|grn/yel - green |A |drivers kick panel |
| RR WINDOW UP/DN|yellow - yel/grn |A |drivers kick panel |
Notes:
*1 In 6 pin white plug behind fuse box
*2 The keyless entry module is white in color, and located in the drivers kick panel.
*3 The OEM alarm plug is to the right side of the steering column. The plug is green.
*4 Drivers side fire wall under hood in a 2 pin plug
2001 civic
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR|yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT|yellow | |back of the fusebox *3 |
| PARKING LIGHTS +|red/black | |back of the fusebox |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| SPEED SENSE|white/green | |PCM *5 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use part number 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
2003 civic
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 The factory alarm plug is a green plug above the drivers kick panel.
Old Jan 23, 2004 | 09:01 AM
Golden_Rocket7's Avatar
Golden_Rocket7
Default thank you for the help
i thank you all for your help and if i need more i sure hope that i can come here and get the same results.
Darin.
Old Jan 23, 2004 | 09:05 AM
honura's Avatar
honura
Seni
Don't you guys like when other people say thanks for you ? :madfawk:
Old Jan 23, 2004 | 09:20 AM
Golden_Rocket7
Default good for u honduras
i dont care if u say that im happy with my results. by the way ure car needs a body kit.
Darin:fawk:
File Type: jpg
Old Jan 23, 2004 | 09:34 AM
honura's Avatar
honura
Seni
Yeah you think ? YOu need to get rid of your kit , rims and change your interior ! Goodluck with that !
