idle problem..need help!!!!
Old Oct 14, 2013 | 11:57 PM
riosandrew's Avatar
riosandrew
Default idle problem..need help!!!!
I have a 93 integea and it idles really low for where it sounds like it wants to shut off.. other then that the car runs great. ..I checked for vaccuum leaks and there are none...I replaced idle control valve and still didn't help. ..all routine maintance is done yet still idles low like at 200-300 rpms but never shuts off...plz help. .. anything is worth a shot
Old Oct 30, 2013 | 09:55 PM
Jennie4226's Avatar
Jennie4226
I am looking for this problem and i will share very soon.
Old Nov 5, 2013 | 01:07 PM
riosandrew's Avatar
riosandrew
Ok koo thnx
Old Dec 14, 2013 | 01:01 AM
Collen414's Avatar
Collen414
I love reading your blog because it has very useful,effective and interesting topics. Best of luck for your efforts.
Old Apr 29, 2014 | 05:27 AM
Collen414's Avatar
Collen414
still waiting for the solution. anyone please post the solution
Last edited by 94civicEX; Apr 29, 2014 at 04:23 PM. Reason: Spamming - http://www.internetbrandsauto.com/advertise
Old May 18, 2014 | 11:42 AM
ChrisS's Avatar
ChrisS
what mods have been done to the engine?
I have a 91 CRX Si that does the exact same thing when it gets close to operating temp. The engine idles fine when warming up (cold to 3/4 of the way to operating temp) and once it reaches operating temp. The Engine runs great while driving.
-the original engine never had any idling problems (I replaced it with a ZC because it had over 206k and was burning oil.)
-the guy I bought the rebuilt ZC from had the head done (5-axis valve seat grinding and shaved .030" off the head to increase the compression)
-I'm not sure if that slight increase in engine compression didn't throw off the MAP sensor reading just enough to cause my idle problem
I'm still searching for a fix for my idle problem too.
take care,
ChrisS
Old Dec 29, 2014 | 03:12 AM
Jennie4226's Avatar
Jennie4226
______________________________
http://www.mynutribulletrecipes.com/
Old Sep 9, 2015 | 07:30 AM
trm4life's Avatar
trm4life
trm4life
personally guys, on my 91, I just rebuilt the IACV. But it sounds to me like your ignition timing has been turned all the way back. Check to see if your distributor is turned. Other than that, it could be a bad spark plug. My integra eats platinum spark plugs for breakfast. Use copper.
