:confused?
Old Oct 28, 2003 | 08:34 AM
DakarM's Avatar
DakarM
Default :confused?
Why would Nissan offer this but you can't get it with
This package is not available with Side-impact Air Bag and ABS option.
® Brembo is a registered trademark of Freni Brembo S.p.A.
Desc: of the pic: Brembo front 4-piston front calipers with 12" vented front discs/10.9" rear discs
$1000 option on Nissan SE-R Spec-V
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Oct 28, 2003 | 08:36 AM
DakarM's Avatar
DakarM
I checked to see if ABS standard, looks like it's not:
-wheel Disc Brakes/ABS
Disc brakes at every corner of SE-R and SE-R Spec V, with big, honkin' 11-inch discs up front. They're vented to dissipate performance-robbing heat for improved stopping action, less fade and longer brake life. Plus, available Anti-lock Braking System (ABS) helps keep you in control of the situation. It pumps the brakes up to 18 times per second, faster than even you can. Which can help keep "stop and steer" from turning into "lock up and skid." View
LCD Squad #0001
Old Oct 28, 2003 | 08:37 AM
sman789's Avatar
sman789
Don't touch me I'm tender
maybe part of the contract with brembo
Old Oct 28, 2003 | 08:38 AM
madlow's Avatar
madlow
I could understand that ABS because it is a brake component but side airbags..
Old Oct 28, 2003 | 08:45 AM
DakarM's Avatar
DakarM
That is also confusing. Maybe the two systems are tied together :dunno:
LCD Squad #0001
