Fuel injectors?
i hear RC is a good brand. they sell new injectors as well as clean up your stock ones. www.rceng.com
If you want a cheap solution get some DSM 450cc injectors. Get them cleaned and blueprinted. You'll need to hook up a resistor box though. The resistor box goes for like 10 and the injectors you can get for around 50 if you're lucky. http://www.cruzinperformance.com/fuelinj.html Go here to get em cleaned. Cheap and effective. :thumbup: Unless you're trying to get some crazy numbers you'll be good w/ 450cc.
Edit: FYI you will need some sort of fuel management to get them to run...s-afc, hondata, aem ems...etc
I've heard people have better results with Bosch injectors over the Nippon Denso's. There's also plate vs. pintle types. You might do a search or email/phone a company that sells both and ask them what their opinion is. If their tech guy has any knowledge, he'll usually be able to help you out.
also...does it matter which generation Eclipse/Talon I get them off of?
there are some from a '91 Eclispe Turbo...and some from a '98 Eclipse Turbo. all are 450cc according to the seller.
'98 Eclipse
'91 Eclipse
'98 Eclipse
'91 Eclipse
