i need some help
Old Sep 18, 2012 | 06:21 AM
hondaboii's Avatar
hondaboii
Default i need some help
I did a motor swap on my 95 Honda civic ex I put a zc dohc and it came with a del sol transmission and I doesn't have the mid half shaft the one tht bolts up to the motor I tried different axls and they don't work cause of tht part does anyone no where I can find one
Old Oct 31, 2012 | 08:49 PM
alton56's Avatar
alton56
Nice post. I like it. Thanks for sharing these information. Keep it up.:irock:
Old Nov 16, 2012 | 08:55 AM
joyee's Avatar
joyee
This method over many years and recommend that you do not assume the trouble is a certain part, as a problem in one area will often show up as a symptom somewhere else. An example is carb malfunctions are often incorrectly assumed to be governor problems.
Old Dec 5, 2012 | 06:29 AM
Griffin779's Avatar
Griffin779
Hi all ,This is not the big problem and i recommend that you do not assume the trouble is a certain part, as a problem in one area will often show up as a symptom somewhere else.
