H22A4 into Accord question
Old Jul 15, 2002 | 08:31 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default H22A4 into Accord question
My swap is done...welll almost.
Heres the problem and hopefully you can figure it out.
The engine is in and running, but it won't idle off of the P13 ECU I have, and it runs rich while running off that ECU.
The engine is a 98 H22A4 and as I said the ECU is a P13 ECU from a 92 Prelude. Everything else on the engine has stayed except for the OBDI conversion.
As far as we know (we have checked a few times now) all the wiring is straight and the correct pins have been jumped.
The car runs fine on my F22 ECU but not on the Prelude ECU....any clue why this would be?
Old Jul 15, 2002 | 08:33 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Oh yeah in case you couldn't tell by engine code it is a USDM motor.
Old Jul 16, 2002 | 02:03 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Thanks for all the replies
It turned out to be a simple wiring mixup. Turns out he miscounted the pin settings and had a wire in the wrong location.
Pics to come soon (probably this evening)
Old Nov 7, 2002 | 07:34 AM
Ryu's Avatar
Ryu
Team Exgen
how did you fix this what was the wrong wire you had wrong?
Im having the same problem, my ECU didnt let me REV past 3000RPM..
turned out to be faulty... but my car wont idle properly
Old Nov 7, 2002 | 10:05 AM
v4lu3s's Avatar
v4lu3s
u also got to post what year accord it is...and the HS hybrid forum will get you faster replies about accords than this one will.
Old Nov 7, 2002 | 10:10 AM
Ryu's Avatar
Ryu
Team Exgen
its in my signature
im gonna go and test the EGR solenoid wiring
i dont remember switching pins A6 and A11 so this could be the problem..
gonna go check the vacuum lines as well
Old Nov 7, 2002 | 10:13 AM
v4lu3s's Avatar
v4lu3s
sorry wsa referring to the first guy.
check the a6 and a11 first thats the most common thing.
vacuum is pretty straight forward as well.
Old Nov 12, 2002 | 11:20 PM
XxRONNxX's Avatar
XxRONNxX
MUGEN Whore!!
Default Re: H22A4 into Accord question
hmmm.....I hear you have to change the injectors on the engine. I believe the injectors on the 98 USDM H22A4 are saturated. Since you're running an ecu intended for peak and hold injectors, you may burn the ecu out. Or, it may be the other way around, peak and hold injectors will burn out a saturated ecu....something like that.
Old Nov 14, 2002 | 08:27 AM
accordhybrid's Avatar
accordhybrid
Default Re: Re: H22A4 into Accord question
You are right the peak and hold will burn out the saurated injectors and also 97 and up prelude motors have saurated injectors and you need to have either stock 92-96 prelude injectors or aftermarket 370 cc peak and hold with a Vafc to control it.
Accordhybrid
mashoutposse
Oct 30, 2005 04:53 PM
blacktopcivic
92+ Civic/EL & Del Sol
Feb 17, 2005 06:32 PM
mizturyous
Feb 15, 2005 08:57 PM
boosted23
Prelude
2
Jan 6, 2005 06:43 PM
Sonny
Engine Swaps, Tech & Tuning
Oct 14, 2004 11:24 PM
