timing belt drive pully - how to remove?
Old Sep 14, 2003 | 10:04 PM
prelude7342's Avatar
prelude7342
Default timing belt drive pully - how to remove?
I'm rebuilding my h22 and not sure how to remove the timing belt drive pulley (not the crank pully outside of the timing cover, but the small gear that drives the timing belt) The service manual does not say. Do I need a puller tool??? Help would be greatly appreciated.
Old Sep 21, 2003 | 06:30 AM
agileauto.com's Avatar
agileauto.com
I don't understand. the drive pulley? how is the crank NOT the drive pulley for everything? please explain and maybe I can help.
Old Sep 21, 2003 | 09:19 AM
BustedLX's Avatar
BustedLX
Rice Rocket
After you remove the harmonic balencer everything should slide off easily once the tension is off the balencer belt and timing belts.
I hope you have the special tool for the H22's auto tensioner.
Old Sep 21, 2003 | 10:06 PM
prelude7342
Ya I got it, it just pulled off w/ some penetrating oil. I was worried that it was pressed on, whew.
Ive had the auto tensioner out before and just made the tool out of a bent piece of metal, pretty simple.
