Beginnings of a starting problem??
Old Aug 29, 2003 | 05:10 PM
96GreenCivic's Avatar
96GreenCivic
Default Beginnings of a starting problem??
Ok,
Vitals.
96 Civic Ex. No mods. 92,000 miles
When ever the car sits for some time (ie the morning), it takes a second or two to start. Unlike when it is still warm, it starts right up. Any ideas what I should do? Is this a possiblity of problems?
Thanx for the advice.
ps, timing and all other belts replaced at 90,000.
new battery back around 70,000
Old Aug 29, 2003 | 06:18 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Check/replace spark plugs and the distributor cap and rotor.
-Harry
AIM: NDcissive
Old Sep 3, 2003 | 07:05 AM
JimBlake's Avatar
JimBlake
When you start it in the morning, does the starter spin more slowly than normal? That might be a weak battery. If it spins just as fast as it ever did, then you're battery is OK.
Otherwise I'll go along with plugs/wires, too.
Old Sep 4, 2003 | 11:42 AM
96GreenCivic
Thanks, I'll go ahead and do that soon
Old Sep 4, 2003 | 05:37 PM
LSVTECKING's Avatar
LSVTECKING
rebuilding
How long is it taking to start?? If its cranking considerably longer oyu may want to do a fuel system presure test to see if fuel is leaking back through the system.
Old Sep 15, 2003 | 08:32 AM
91Accord's Avatar
91Accord
Huh???
I know you just replaced the timing belt. Are you certain that the timing is correctly adjusted???
