help
Old Aug 6, 2003 | 05:15 PM
bustah49's Avatar
bustah49
Mr. Motorhead
Default help
i have a 97 civic dx hb. i put a header on it and in 4 or 5 days it throws a code..i think it is because i have no cat. is there some kind of wire or sumthing that will help cure this problem?
Old Aug 6, 2003 | 05:22 PM
Snoopy's Avatar
Snoopy
been there done that
you need to plug your second o2 sensor in. why do you have no cat? :eh:
Old Aug 6, 2003 | 05:31 PM
bustah49's Avatar
bustah49
Mr. Motorhead
the 2nd o2 sensor is plugged in....on the d16y7 motor, the cat is right below or part of the manifold
Old Aug 6, 2003 | 05:34 PM
Snoopy's Avatar
Snoopy
well what kind of code are you throwing?
Old Aug 6, 2003 | 05:36 PM
bustah49's Avatar
bustah49
Mr. Motorhead
it is throwin 2 codes....#1 o2 sensor bad.......and cat is bad. i took it off and have had my stock manifold on now for 2 wks.....no codes. what gives?
Old Aug 7, 2003 | 12:30 AM
Hondadog's Avatar
Hondadog
Did you wire new O2 sensors in? If you spliced in new O2 sensors you need to solder them or else the resistance will be wrong and throw a code.
Dog
Old Aug 7, 2003 | 11:01 AM
egzivic's Avatar
egzivic
You have to have a cat to make the codes go away. Here is why:
The point of two O2s is to test the cat and make sure it is working. The first O2 reads before cat oxygen levels and the second reads after cat oxygen levels. The second reading should be different if the cat is working. I order to make you codes go away have a cat istalled with a O2 bung after it. Install the O2 sensors in the right places as in the original configuration and you will be set to roll with no codes.
