Vtec signal wire?
Old Jul 19, 2003 | 03:17 PM
EBPSI's Avatar
EBPSI
Default Vtec signal wire?
Can anyone explain where to find the VTEC signal wire o what it looks like. I know where the vtec soleniod is so if that helps...
Old Jul 22, 2003 | 07:37 AM
PHiZ's Avatar
PHiZ
BOOST GOD
should be right near the solenoid, green wire, yellow stripe (if I recall correctly)
-PHiZ
Old Jul 22, 2003 | 01:14 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
If you're looking for it on the harness connection do a continuity check with a voltage tester. You can get one at RadioShack for like $12. That's how I found all the wires I needed when doing my swap. You know where it is on the motor, just not on the connectors.
hih
