95 teg overheating
Old Jul 6, 2003 | 03:50 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Default 95 teg overheating
My friend's teg is overheating, on the temp gauge, and it runs itself dry.
He has replaced the thermostat, and the water pump, and redid the timing while he was at it. timing is still one tooth off
He doesn't think it's the head gasket, because there is no oil in the coolant, and no coolant in the oil.
Where should he look next, thanks guys.
-PHiZ
Old Jul 6, 2003 | 08:51 PM
PHiZ's Avatar
PHiZ
BOOST GOD
he also did a coolant flush, what to look at next guys.
We heard that ignition timing being off can cause the car to overheat, he's checking that tomorrow.
What else guys.
-PHiZ
Old Jul 7, 2003 | 09:52 AM
PHiZ's Avatar
PHiZ
BOOST GOD
TTT, anyone?
-PHiZ
Old Jul 10, 2003 | 07:03 PM
cartuner's Avatar
cartuner
I would check to see if the radiator cap is holding the specified PSI. If this problem happened after a coolant change then make sure you bleed air out of the system when filling it up with coolant. There could be air trapped in the head if not bleed out. Also have the whole system pressurized to check for leaks. It can also be a clogged radiator too so look inside your radiator if it's got build-up in there.
Old Jul 11, 2003 | 07:31 AM
caylan's Avatar
caylan
Default I HAVE THE SAME PROBLEM
Yeah, I'm having my mechanic look @ all of the ideas here. seems even after my thermostat& radiator swap-out, it's still running too hot.
92 Civic Si
Old Jul 12, 2003 | 03:23 PM
b18b1civic's Avatar
b18b1civic
happen to my car radiator fan motor was gone
Old Jul 12, 2003 | 10:52 PM
jeepxj66's Avatar
jeepxj66
Mines about dead from overheating. No sign of water in the oil. Combustion residue in the water is minor. Eats water FAST nowdays but not bad at first. Found a rusty spark plug for the first clue. A month later I have 2 rusty plugs and pulling the plugs on a hot engine with pressure still on the radiator I can hear the hissing from the two center cyl's.
Hope its just a gasket but with high miles and lots of grime on the back of the car I think its time for that B20 I been wanting.
