water in oil
Old Jul 8, 2002 | 10:13 PM
maxrpm's Avatar
maxrpm
Default water in oil
I drained my oil and the oil seemed like it had water (coolant) in the oil. Is it possible other than a cracked head or block for water to get in the oil. Like if the head gasket went bad some how. One more question i think my third cylinder is not working properly. I pulled the spark plug and the car doesn't even change in idle it has a constant noise. teh rest of the cylinder would drop in idle and soound like its going to die. Do i have a bent valve or what can cause this. Any help please.
Old Jul 8, 2002 | 11:47 PM
wadzii's Avatar
wadzii
fear the dark side
sometimes pulling a plug wire wont change it........ my h22 did that, all would make the idle change but one. nuthing was wrong. as for water in the oil, that usually indicates a blown head gasket. you should do a compression and leak down test to get more conclusive results
Old Jul 9, 2002 | 10:37 AM
maxrpm's Avatar
maxrpm
well i was going to do a compression test but i already took the head off. Im waiting for the new head gasket to come in. Does anyone know if the cr-v head gasket will fit the b18b1 head? Mines been honed to 2.0 and the b18 is a little small. Hope this will solve my high pressure in the radiator and the oil problem.
Old Jul 9, 2002 | 01:58 PM
EG6's Avatar
EG6
the b20 gasket should be fine. Your bored to 84mm???
Old Jul 9, 2002 | 03:14 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Did you drain the oil after pulling off the head?
-Harry
AIM: NDcissive
Old Jul 9, 2002 | 09:52 PM
maxrpm's Avatar
maxrpm
it was before i pulled the head. I changed my oil before that already and it had some water in it just a little. and when i came back from my trip (about 1000miles) i decided i would change tyhe head gasket to see if it solved my high pressure in the radiator and over heating i was getting. So, i decided to drain the oil first and this time the oil was like a watery brown color like mud.
Old Jul 14, 2002 | 08:11 AM
black2k1vtec's Avatar
black2k1vtec
yup, head gasket, cracked block, are usually the problems.
sandersonbhd
Engine Swaps, Tech & Tuning
4
Dec 30, 2004 12:01 AM
