rpm unstable when warming
Old Jul 4, 2003 | 09:11 PM
keefungliu's Avatar
keefungliu
Default rpm unstable when warming
hi, i got a 2002 accord ex. it only got 10k miles. when i warm up the car in the morning, the rpm needle will shake a little until it get down to 1000 rpm. i know the old cars will have those problem. but my car like brand new. so what's problem? anyone help please!
Old Jul 4, 2003 | 11:00 PM
dresden_k's Avatar
dresden_k
RIP H22A-CB7 :(
How badly is it shaking?
Old Jul 5, 2003 | 04:47 PM
crxb16er's Avatar
crxb16er
its normal for the needle to first be a bit higher and then come down to its normal idling speed, on warm up it can be as high as 1.5k rpms normally, i wouldnt be worried unless the needle is bouncing (at which point id suggest checking for vacume leaks) but ur cars idle is controlled by the ecu so i really wouldnt worry about it.
Old Jul 6, 2003 | 03:05 AM
keefungliu's Avatar
keefungliu
but my car like brand new. new car shouldn't has that problem, right?
Old Jul 6, 2003 | 10:17 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
i think all hondas put a little more gas into the engine till it was warm, which would explain the higher rpm at idle. the shaking im not sure tho. check vacuum, fast idle valve...or anything related to idle.
Old Jul 6, 2003 | 10:46 AM
crxb16er's Avatar
crxb16er
all cars are different, the b16 i had in my car was properly balanced, had the EXACT same compression on all cylinders and motor mounts were in perfect condition, the new zc i put in does not move at all in the car, u can turn it on and look at the engine in the bay and it stays perfectly still and i have not yet touched it straight from japan, so....???? just depends on the engine, as for the needle shaking that may be an ignition system issue, ie cap and rotor, spark plugs etc. but on a new car should all be fine still..,.
Old Jul 8, 2003 | 04:03 AM
Prince's Avatar
Prince
I am certainly no expert at these things but I would suggest check your oils and especially coolant. I had a coolant leak and my car was doing something close to what you are saying
