brake swap generational question
Old Jul 3, 2003 | 07:36 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Default brake swap generational question
I have an older integra sitting, waiting to give up it's rear brakes. I'm still searching, but I'm trying to find a definitive answer of what generations of teg's will bolt up to my 6th gen civic.
If anyone can offer experience, thanks, I'll be sorting throught 14 pages of search results, if ya need me.
-PHiZ
Old Jul 5, 2003 | 07:11 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i think that any 90-02 integra trailing arm will work, but i could be mistaken. you can't use any integra lca on 6th gen civic's.
i'd take some measurements of the integra trailing arm and the civic trailing arm
if all the mounting points are same you outta be money
Project EVA - The Track Package
Project EVA
Old Jul 5, 2003 | 07:20 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Thanks bumnah, so you're saying use the civic LCA, and the only loss will be the mounting points for the rear sway, right?
-PHiZ
Old Jul 6, 2003 | 05:17 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
well i believe all 6th gen civic's use the same rear lca's and they all have a place for the rear sway bar endlinks.
Project EVA
Old Jul 14, 2003 | 09:42 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Ok, I'm semi-confident, I can make the suspension hardware work.
I will need different rear shocks, I got that covered.
What about springs?!?!!
I want to buy an eibach pro-kit, but they don't part out the front/rears. It's all 4 per your application.
-PHiZ
Old Jul 25, 2003 | 03:59 PM
PHiZ's Avatar
PHiZ
BOOST GOD
answer on springs? In the front I just swap the knuckles, so the spring perches/shocks will be the same. But in the rear, are rear teg springs, and rear civic springs the same (shape at least?)
-PHiZ
