Electronic Load Detector
Old Jul 2, 2003 | 07:07 AM
Jprosario's Avatar
Jprosario
Default Electronic Load Detector
I have a Civic 2000 si, just got a b18 swap, I think one of the IAB wires came loose and grounded. I think that is what is causing my code 20 on the ECU. Is this what caused it and what are my options, do I really have to replace this unit, if I do can I grab one off another honda? What are my options? My Speedometer is not working, vtech aint kicking in. PLEASE HELP!
Old Jul 2, 2003 | 04:56 PM
PHiZ's Avatar
PHiZ
BOOST GOD
what does that have to do with the ELD? What exactly does the ELD do?
-PHiZ
Old Jul 4, 2003 | 07:40 AM
Civic Type Sev's Avatar
Civic Type Sev
I just swapped a B16A2 from a 97 del sol VTEC into my 97 Civic DX. For wiring I just reused my dx harness and added wires as needed. I checked the wiring diagrams from both cars and can't see anything different for the Electrical Load Detector wiring but yet I get the cel code. I was wondering if the ELD is different and if I should swap this too.
Old Jul 5, 2003 | 04:08 PM
PHiZ's Avatar
PHiZ
BOOST GOD
again what does the ELD do, I have an extra wire on the harness I just made for the weird swap I'm doing. And I'm just curious what the ELD does. From it's description, I'm guessing it causes the car to idle higher under electrical load, so the alternator puts out more juice...
-PHiZ
Old Jul 5, 2003 | 04:34 PM
crxb16er's Avatar
crxb16er
yah kicks the alternator up and add's more power where needed, ie spark plugs and other systems, makes it so ur lights dont change with the beat to ur music
Old Jul 9, 2003 | 05:10 AM
Civic Type Sev
OK... I found out how to get rid of my ELD cel code 20. Last night I finally wired my secondary oxygen sensor and both codes dissapeared (20 and 65). As I was wondering why... I realized that the oxygen sensors on obd2 hondas have 4 wires. 2 for the actual oxygen sensing and the other 2 are for the oxygen sensor heater. Since the ELD senses the ''total'' electrical load, it was seing that the circuit for the secondary oxygen sensor heater was open. And that is why it was throwing the code. I'm sure as a quick fix, I could have just connected a resistor between the two oxygen sensor heater wires and the cel code 20 would have dissapeared.
HMmmm... sounds like a test I will have to do in the future.
I guess the conclusion from this is that to get rid of this code... you have to make sure that every important component drawing current from your battery must be connected.
Hope this helps.
Old Jul 11, 2003 | 09:44 AM
Civic Type Sev
Make sure everything is connected. Are you throwing any other cel codes?
Old Jul 11, 2003 | 09:11 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Hrm, I wonder how that works when you do a OBD2->OBD1 conversion, is the ECU smart enought to subtract that extra load from the equation to keep the ELD routine happy, must be. hrm.
-PHiZ
Old Jul 14, 2003 | 04:01 AM
Civic Type Sev
hmmm... good question. Maybe the obd2-obd1 conversion harness just short circuits the secondary oxygen sensor heater circuit so that the ELD circuit is closed??? Can anyone confirm that?
Old Jul 14, 2003 | 07:09 AM
PHiZ's Avatar
PHiZ
BOOST GOD
no, I don't htink so, there just aren't pins on the OBD1 side, so th secondary is just an open circuit.
-PHiZ
