dry sump and regular oil system
Old Jun 21, 2003 | 03:23 PM
Snoopy's Avatar
Snoopy
been there done that
Default dry sump and regular oil system
whats the difference between a dry sump system and a regular oil system? and what advantages, if any, would one have over the other?
Old Jun 21, 2003 | 04:04 PM
crxb16er's Avatar
crxb16er
humm... never heard of a dry sump system, how would ur rods get oil? normally ur crank and bottom of the rods are in the oil sump and as the crank turns it splashes the oil around getting everything else nice and lubricated. ????
Old Jun 21, 2003 | 05:15 PM
ambition's Avatar
ambition
StillDPG
:thumbup: good question
Old Jun 21, 2003 | 06:00 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Its a pressurized oiling system, incase under hard cornering the oil sump is not submerged in oil, it takes it from a presurized oil tank, which takes over the duties of the sump, it allows for a shallower oil pan. I think, its somewhere close along those lines.
Old Jun 21, 2003 | 07:54 PM
CivicRacr's Avatar
CivicRacr
what he said :thumbup:
Old Jun 23, 2003 | 02:13 AM
Dave C's Avatar
Dave C
Not quite correct but going the right way. In a dry sump system oil is stored in a remote tank. Oil is scavenged out of the engine sump by 2 or more pumps and sent to the remote tank. Oil from the tank is then fed to a pressure pump for engine oiling.
Dry sump oil pans are much shallower than wet sumps (better ground clearance). Oil pressure is maintained during extreme cornering. Less windage losses and oil whipping at high RPM.
Down side is it's a more complex and expensive system. Also many more points for oil leaks to occur.
Old Jun 23, 2003 | 03:06 PM
likaciv's Avatar
likaciv
:bigok:
