temperature high
Old Jun 14, 2003 | 05:41 PM
keefungliu's Avatar
keefungliu
Default temperature high
my 86 prelude's temperature gauage running high. it always over half after drive around little bit longer. but i never reach the redline. is that mean my radiator going bad? i open the air conditioning everytime i drive, but i don't open with AC. will that help cool down my engine?
Old Jun 14, 2003 | 06:20 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
you have plenty of coolant? and did you recently change it?
Old Jun 14, 2003 | 06:32 PM
smakdown's Avatar
smakdown
Does the temp gauge fluxuate alot? Like slowly rise up over the middle line, and then go back down? I had the same problem, it was a bad thermostat. I would change your thermastat if it hasn't been done after a few years, just don't let honda do it or they will charge up the ass.
Old Jun 14, 2003 | 09:20 PM
keefungliu's Avatar
keefungliu
my coolant was ok. and i haven't change it.
yah, it is kinda rise up to the middle first, then it continue rise to over 3/4. then if i open the fan, it will drop a little bit
Old Jun 14, 2003 | 10:55 PM
silverstreakin
TRD japan ownerages
yeah...id try a thermostat
and make sure your cooling fan is kicking on
Old Jun 15, 2003 | 07:59 AM
crxb16er's Avatar
crxb16er
yah check cooling fan operation, drain and flush the radiator, install new thermostat, and check all hoses while ur at it. running the stock engine u shouldnt need to change out ur radiator unless its leaking.
Old Jun 15, 2003 | 05:40 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Check your ground wires, those can make your needles do weird things.
