a 96 civic DX head -- to a 96-00 single overhead vtec
Old Jul 6, 2002 | 09:49 AM
xbladr's Avatar
xbladr
Default a 96 civic DX head -- to a 96-00 single overhead vtech
I was wondering i got a 96 civic DX and some guy is selling a 96-00 Civic single overhead cam vtech head This head had a three angle vavle job, was ported, polished and milled. Was used for appox. 2000 miles. would this be worth putting in my civic. and is this something i could do myself and how hard would it be to do? also is there anything else i would need in order to install it? thanks please let me know
Old Jul 7, 2002 | 10:46 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You would need to run an oil line to it, and some way to control the VTEC crossover(VTEC ECU, RPM switch, VTEC controller, etc).
If you can get it for cheap, go for it.
Old Jul 8, 2002 | 02:09 PM
xbladr's Avatar
xbladr
i can get it for like 175 or so
Old Jul 9, 2002 | 07:06 AM
jdblack1's Avatar
jdblack1
You wouldn't have to run an external oil line. Just remove the pressure jet from the deck of the block prior to installing a VTEC head.
You need the 96+ Civic Ex head gasket, timing belt.
You should replace the waterpump as well. Also see if you can the intake manifold. It will flow better.
Old Jul 9, 2002 | 09:12 AM
xbladr's Avatar
xbladr
I am fairly new to this so how hard would this be to do and how much time would it take normally. also how much would it cost for all the other stuff u had listed there jdblack cuz i was hoping all i would need to do is just get the head and get a new distributor and try to install not knowing how but i figured id give it a shot
Old Jul 9, 2002 | 09:24 AM
jdblack1's Avatar
jdblack1
Why would you change the dist.? Put the head on with new gasket, timing belt, and waterpump. I'd say just get a Vafc for VTEC fuel enrichment.
If you've never changed a head then go ahead and look at all day.
Tankard
CRX & Pre 92 Civic
3
Aug 16, 2005 05:11 PM
compfreak2002
Mar 6, 2004 12:24 PM
Turbo_Teg
Dec 10, 2002 08:10 PM
