how much boost?
Old Jun 10, 2003 | 11:09 PM
delsol2001's Avatar
delsol2001
hustlin member
Default how much boost?
how much boost can a stock ex motor handle?
how much with a built block, pistons, rods, block guard or sleeve?
Old Jun 11, 2003 | 06:03 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Most stock Hondas will hold up to around 12-14 psi with perfect tuning. Beyond that the stresses get high enough that rods are known to bend, fold, or break.
With a completely built engine, the sky is pretty much the limit. Again, perfect tuning is the key.
-Harry
AIM: NDcissive
Old Jun 13, 2003 | 12:39 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Harry pretty much covered it, but I would stay under 10lbs of boost on a stock D16 just to be safe, with the occasional 12psi run. D series rods are toothpicks, and the pistons aren't much better. Stock ringlands usually account for piston-related damage.
Old Jun 13, 2003 | 05:46 AM
1stGenCRXer
I knew my post was too short... yeah, the ring lands on stock pistons can be pretty weak, especially if you make a few higher boost runs before getting everything tuned correctly. But in general, 12-14 psi on a continuous basis on a stock engine will most likely kill it, even with great tuning.
-Harry
AIM: NDcissive
Old Jun 14, 2003 | 05:20 PM
ambition's Avatar
ambition
StillDPG
daily driver i would only boost 6-8psi... all that boost takes its toll
built engine 1 bar sounds nice.
im sure you could push more but i'm thinkin daily driver you'll be fine wit these figures.. but i am no boost expert ethier. but think about longevity!!
when you up the boost don't you have to go through the whole tuning process again?
Old Jun 20, 2003 | 03:56 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
yea, when you have your car on a dyno, it's pretty much tuned for a certain boost level. you cant get it tuned for 6 lbs and just turn it up to 10 and expect to run as well. it also depends on how often you hit high boost.
Old Jun 20, 2003 | 09:16 PM
IntegraRacer's Avatar
IntegraRacer
pretty much the past replies really covers everyting, In my opinion just run like 6-8 psi no more then that unless you want to damage your car but my opinion.
