brake system
Old May 30, 2003 | 04:31 PM
civic401's Avatar
civic401
Default brake system
i drive a 1998 civic lx and i want to convert all my brakes into gsr. can some one give me some info on this. thank you
Old May 30, 2003 | 11:25 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
http://tech.hybridgarage.com/tech/brakeswap.html
That's for a 5th gen, but it's basically the same. You can use 94-01 Integra, Del Sol, or 92-00 Civic parts. If you use Del Sol parts, you'll need Civic or Integra parking brake cables. If you have ABS and want to retain it, you'll need the ABS sensors from the donor car(Some rear-disc Civics had ABS, as do all GSR Integras, I'm not sure about Del Sols).
As for the fronts, they usually come as an entire spindle/knuckle/hub assembly, so you just swap the entire assembly over with the lines from the donor car. It'd be a good ida to use new lines, pads, and rotors. You may also want to see if the donor calipers need to be rebuilt. If your existing master cylinder is 13/16", I would upgrade to at least a 15/16" MC, or go to a 1" MC/booster combo.
Old Sep 20, 2003 | 01:58 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
search option ownes me
see kids, it works :thumbup:
Old Sep 20, 2003 | 07:30 PM
Falkon's Avatar
Falkon
still alive
Del Sol VTECs have ABS.
Old Sep 20, 2003 | 10:39 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
This isn't engine tech material people...
-Harry
AIM: NDcissive
Old Sep 22, 2003 | 04:57 PM
19.3secS2K's Avatar
19.3secS2K
so does my civic lx
