FlyWheel?
Old May 28, 2003 | 04:10 PM
forum95's Avatar
forum95
I'm Cooler than You
Default FlyWheel?
How much Will a much lighter flywheel help on a 4cylinder car like a 1996 accord? will i see any major torque gains?
Old May 28, 2003 | 04:49 PM
crxb16er's Avatar
crxb16er
u'll see possible hp gains and faster rpm gains, as well as higher rpm capability, you will see lower torque though, using a lighter flywheel causes ur engines moving components to spin easier but with less force. on an accord which may need the higher torque its ur call, if u had a little car like a crx or a civic id say go for it, but if u drive around with passengers often then ????
Old May 28, 2003 | 05:19 PM
6genx's Avatar
6genx
Swami
Do you live where it's very hilly? Mountains or foothills? If so I would keep the stock flywheel, the extra weight keeps the momentium on the rotating assembly so you don't have to go down 2 gears or run WOT to get to the top of the hill. Just my .02
Old May 28, 2003 | 08:39 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Yup, you have to understand, a lightened flywheel spins up faster, but also looses momentum faster. So you have to racecar shift at all times.
-PHiZ
Old May 29, 2003 | 05:58 PM
forum95's Avatar
forum95
I'm Cooler than You
ooh i see, thanks for your opinions....
