Advance/Retard timing question!
Old May 26, 2003 | 05:26 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default Advance/Retard timing question!
Okay sorry i'm a noob at timing and stuff but when i advance my timing in my 88 crx si engine should i have my car off or on? or doesn't it matter, would it hurt my car if i have it running while advancing my timing? thanks!
Old May 26, 2003 | 06:31 PM
Snoopy's Avatar
Snoopy
been there done that
im no expert but i think you'd have to have the engine running in order to get a spark so the timing light can have something to go off on. :thinking:
Old May 26, 2003 | 08:41 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
I always do it with the engine running.
Old May 27, 2003 | 04:11 AM
ZiviCase10287
RacinMasonC
ok thanks, also how far do you guys think i should advance my timing? i have an 88 crx si engine... d16a6.
Old May 27, 2003 | 04:32 AM
Beatbom's Avatar
Beatbom
not too much as my guess is you'll just endup 'confusing' the ECU.
Then, my 2nd guess will be that the ECU will compensate to make it what it should be.
Finally, I think that there is more to do on a Electronic controled engine than just move forward the timing.
Isn't that why kids get them 'chips' put in (to control timing AND fuel/air intake etc..)?
You ain't dealing with a simple early 80's GM engine anymore!
Old May 27, 2003 | 06:34 AM
luti's Avatar
luti
On my car (98 Civic) to adjust the timing and not have the computer recompensate you have to jumper the plug by the ECU used to download the codes.
