Stroke Question
Old May 7, 2003 | 09:46 PM
The Beav's Avatar
The Beav
i
Default Stroke Question
what are the advantages/disadvantages of stroking out a motor to a higher displacement, i see alot of people do this (especially american car guys) and i'm curious what it accomplishes
Old May 7, 2003 | 10:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The main advantage is a longer stroke which means more torque/power. A major disadvantage is the change in rod/stroke ratio.
Old May 8, 2003 | 08:19 AM
The Beav's Avatar
The Beav
i
roughly how much of a power/torque gain is it?
Old May 8, 2003 | 08:20 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
http://www.importreview.com/dyno.html
Old May 8, 2003 | 08:43 AM
The Beav's Avatar
The Beav
i
that's got some cool charts but i don't see how it helps answer my question much?
Old May 8, 2003 | 04:28 PM
SRT_Andy's Avatar
SRT_Andy
The main disadvantage of a stroker kit is that the larger the displacement the thinner the cylinder walls/sleeves will be. Example: Most engine builder's will only stroke a 1.6L to 1.8L if it will be used for turbo/nitrous applications. This also helps ensure the cylinders do not "float".
Old May 9, 2003 | 02:25 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
How does a stroker kit make the sleeves thinner? Are you perhaps thinking of boring the cylinders(which also increases displacement)?
Old May 12, 2003 | 08:52 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
more stroke = more piston speed = lower redline
