I broke my radiator hose
Old Apr 13, 2003 | 08:09 PM
blkdragteg63's Avatar
blkdragteg63
Default I broke my radiator hose
whats up guys, apparently it seems that i keep having problems with my teg. I guess when it rains , it pores. Anyway, i was driving home tonight and noticed steam coming from my hood. I look at it when i got home, i saw that i had antifreeze everywhere and i could smell it. The top radiator hose had a busted hose in it. Would this be maybe just because its old and needed to be replaced or could this be something else ? I had radiator problems a few months ago, but that soon ended when i got a c&r radiator. What would make this happen?
thanks
Old Apr 13, 2003 | 08:20 PM
bambbrose's Avatar
bambbrose
usually just from an old hose. Probably had a weak spot. What does the hose look like on the inside?
Old Apr 13, 2003 | 08:24 PM
blkdragteg63
it looks pretty clean on the inside.. Where it split is right after the hose connects to the radiator neck, about an inch from that. Its a split in it about an inch long. Before it broke, whenever the car was running and warmed up that hose was pretty tight if you tried to squeeze it. I wonder if its blocked up somehow and just busted because it couldnt move.
Old Apr 13, 2003 | 10:33 PM
AwwsChwA's Avatar
AwwsChwA
could be a lotta things, especially with the aftermarket radiator. Maybe the hose neck on the radiator is too large for a stock hose? Hose could be old and brittle? Too much fluid pressure? Cheap replacement hose?
Old Apr 13, 2003 | 10:45 PM
blkdragteg63
The hose doesnt look and wore out, but it could be a cheap one.the hose neck on the radiator is just the right size for the hose.
Old Apr 13, 2003 | 10:47 PM
blkdragteg63
i guess im going to get another stock hose and see what happens, im just trying to narrow it down and see if its just the hose or anything else..
Old Apr 14, 2003 | 09:12 AM
blkdragteg63
should the upper radiator hose be really hard to squeeze when its warmed up? i know its hot, but the hose looks like its wanting to bust..
Old Apr 14, 2003 | 03:45 PM
JimBlake's Avatar
JimBlake
It's supposed to get hard. When the car warms up the coolant is at maybe 16psi pressure.
Old Apr 21, 2003 | 01:29 PM
york2600's Avatar
york2600
It's a bit too late, but if this happens to anyone else make sure to hose down the car right after it happens. After I flushed my system I put the hose on too loose and on the drive back it blew off. Well it got on the hood of the car and it ate right through the clear coat. Screwed the shit out of my paint. Coolant is acidic. Not nice stuff.
-Tim
Old Apr 23, 2003 | 01:25 AM
MikeR's Avatar
MikeR
should just be an old hose, also could have been weakened while removing it from the old rad. as far as the paint, try some mild compound and or clear coat scrub, even better with a buffer.
