cold air intake in rain/snow
Old Apr 13, 2003 | 05:18 PM
franscum's Avatar
franscum
Default cold air intake in rain/snow
i just had one installed, and my freind says once it rains alot or snows my intake is gona suck up the moisture and screw up my engine...true?
Old Apr 13, 2003 | 05:56 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
depends, a lot of rain and snow... MAYBE... very unlikely unless you go through a puddle of rain a foot high... or if your front end goes into a snow bank and then your filter is covered in snow, then possibly... if its just raining a little or snowing like 1-3 inches, don't worry about it.
Old Apr 14, 2003 | 12:58 AM
JobeHonda's Avatar
JobeHonda
Tell your friend to put his mouth where the filter goes and tell him to tell you that comment again.. Unless your driving that thing in the ocean, you got nothing to worry about
Old Apr 14, 2003 | 05:57 AM
NVS's Avatar
NVS
That's Mr.NVS to you!
So does AEM make those bypass filters just to scare people and make money?
Old Apr 14, 2003 | 09:22 AM
PHiZ's Avatar
PHiZ
BOOST GOD
yes?
Well that bypass is designed so that if the intake is completely submerged, it will not suck up 100% water like a straw. The bypass will kick in. I do not believe they were enginered to protect against ambient humidity.
-PHiZ
Old Apr 16, 2003 | 06:31 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
AEM had a big recall on those bypass valves a while back - I think the foam on the inside was coming apart and wrecking engines. The last I heard is they fixed that problem, but that kind of defeats the purpose of having a safety device in there the first place. I think the reason people have a problem with CAIs is they don't properly reinstall the fender well liners, so the water has a clear shot of douching the filter. I live in the rainy northwest and haven't had any problem with my CAI.
Old Apr 16, 2003 | 12:21 PM
preylude99's Avatar
preylude99
yea, its actually safer w/o the bypass valve because of what used to happen with the foam, dont know if they fixed that or not.The chances of hydrolocking are slim, and especially if you have a decent splash panel protecting the filter, youd really have to try to get it hydrolocked....
Old Apr 16, 2003 | 12:27 PM
crxb16er's Avatar
crxb16er
yah some occasional moisture going thru ur filter will only help decarbonize ur engine cylinders (which is a good thing), now obviously if ur driving in water and its splashing all over the filter u may have something to worry about, but ur friend was probably just pulling ur chain, you shouldnt have nething to worry about i back up everyone elses statements
Old Apr 17, 2003 | 02:02 AM
ManTiS's Avatar
ManTiS
NinJA
The bypass works very well. When your filter is completely SUBMERGED in water and you have the throttle to the floor, water will start to come up the tube (like a drinking straw.) With the bypass in, the flaps will open and allow air to get through -bypassing the water.
However, the bypass defeats the cold air in the first place because it's an obstruction to the flow of incoming air; even AEM admits to this.
I ran a CAI for years in winter/rain with no problems. I had bought a bypass, but I sold it.
