This may be a gay question
Old Apr 12, 2003 | 10:45 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Default This may be a gay question
ive done a lot of stuff on my own car i.e. oil change,trans flush,radiator swap,bolt ons,valve adjustments but i have never changed a power steering belt....lol ya ya i know.
but i just need to know how to take it off properly, do i just loosen the 2 mounting bolts on the pump and swing it back enough for the belt to come off? then when i put the new belt in i put the tension amount for a new belt then let the engine run for about 5 minutes after i go from lock-to-lock with the steering wheel, then adjust the tension to used belt tension then check the belt deflection? is that how?
Old Apr 13, 2003 | 01:32 AM
drift's Avatar
drift
Flaccid Member
get a manual.
Old Apr 13, 2003 | 11:15 AM
NeverBX's Avatar
NeverBX
i do have a manual, i have a helms. it just not very clear on the removal on the PS belt, it just shows how to adjust it.
Old Apr 13, 2003 | 12:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You loosen both mounting bolts, then you pivot the bottom of the pump toward the block to release tension on the belt. With the pump pivoted all the way toward the block, you should be able to slide the belt right out. As for tension on the new belt, if it's tight, but you can still twist it half a turn in either direction, that should be fine.
Old Apr 13, 2003 | 08:26 PM
NeverBX's Avatar
NeverBX
thanks for your help dude, came out perfect...lol damn my old belt had some cracks already..lol
thanks
Old Apr 14, 2003 | 12:10 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
np, glad to be of service
Old Apr 17, 2003 | 02:04 AM
ManTiS's Avatar
ManTiS
NinJA
leave it off; i did and I grew muscles
