serious problem(i think)please help
Old Apr 11, 2003 | 11:46 AM
vicious_eg's Avatar
vicious_eg
Default serious problem(i think)please help
ok here is the problem, for some odd reason oil is flowing from my throttle body...since i found that out i replaced my head gasket and my intake manifold and got my head milled....do you think that will have solved the problem or do you think it could be something else like a hose ran to the wrong place on the intake manifold...please help
Old Apr 11, 2003 | 12:24 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Are you sure it's not coming from the breather hose from the valve cover?
Old Apr 11, 2003 | 12:36 PM
vicious_eg's Avatar
vicious_eg
i dont think so is that possible???
Old Apr 11, 2003 | 12:42 PM
preylude99's Avatar
preylude99
yea its possible, most of my friends, and mine gets a little oil into the end of the throttle body and it came from the breather valve hose,check it out and see cause if thats the problem even when you did all that stuff youll still get a lil oil.....
Old Apr 13, 2003 | 01:52 PM
JimBlake's Avatar
JimBlake
... & if your PCV valve is plugged up with crud, you'll get even more oily mess thru your breather hose. Check out your PCV valve.
Old Apr 13, 2003 | 04:53 PM
vicious_eg's Avatar
vicious_eg
got a new pcv valve works good now...now oil light wont go anyone know why that is???
Old Apr 14, 2003 | 03:38 PM
JimBlake's Avatar
JimBlake
What kind of engine? My Integra's PCV valve is hidden down under the intake manifold, so maybe you pulled the wire off the oil pressure switch while you were changing it???
