Identifying the engine in your car
Old Aug 5, 2010 | 06:43 PM
Ice0027's Avatar
Ice0027
Default Identifying the engine in your car
I'm not too familiar with engine swapping and all that. To make a long story short I apparently got an integra type r engine swapped into my 98 civic ex. All I know is the engine says B18c on it but there seems to be many variations. The whole thing ended in a court case, but basically all I want to know is how can I tell exactly what engine is in my car?
Old Aug 5, 2010 | 07:49 PM
Snoopy's Avatar
Snoopy
been there done that
left side of the engine as you're facing it, just below where the head and block meet. there should be a flat spot with the engine code stamped on it.
Old Aug 5, 2010 | 10:10 PM
Ice0027's Avatar
Ice0027
It says just B18C, how do I know if it's b18c spec r or gsr or even one of the b18c1-5? Sorry I really don't know much. I was told a jdm b18c type r but considering how the swap went down, I'm not sure if I can trust that.
http://en.wikipedia.org/wiki/Honda_B_engine#JDM_B18C
Old Aug 6, 2010 | 03:05 PM
Snoopy's Avatar
Snoopy
on the head right above one of the exhaust ports is a stamp with the head code. if it says pr3-xxx it is more than likely a jdm type r engine. if it says p73-xxx it's most likely a jdm gsr engine.
fyi, jdm engines dont have a number after the letter designators ie. b18c1, b18c5, etc. only usdm engines will be stamped that way.
Old Aug 6, 2010 | 10:20 PM
Ice0027's Avatar
Ice0027
The code said P72-1
Old Aug 7, 2010 | 07:52 PM
Snoopy's Avatar
Snoopy
Its most likely an sir-g (jdm gsr) then. Or it very well could be an itr block with an sir-g head. Only way to tell otherwise is to look at the internals. But those are easily replaced too.
Old Aug 8, 2010 | 08:02 PM
Ice0027's Avatar
Ice0027
That's a bit disappointing. Thanks for all your help though and bearing with me!
