sputter and stall
Old Apr 8, 2003 | 10:54 PM
matty1821's Avatar
matty1821
Default sputter and stall
Ok I thought i fixed my problem, but didnt. My gsr one day started to sputter and then stall out and die. It does this when i just tap the gas or try to start out, sometimes it makes it past the sputter and revs fine in the upper rpms. When i tried to start the engine exhaust shot out of my intake. Checked compression everything is fine, new fuel filter, plugs wires, I checked my timing belt which was changed about 20,000 miles ago and the belt was really loose but valves seemed ok. So I tightened it up and it seem to be running all right, not moving. I pulled out of my driveway and then in going down my road it did the same thing, sputter, lose revs and die. I havent checked it after that, There are no codes, and I have no major engine work. Tensioner broke, new belt, Fuel pump, vacum? Please help
Old Apr 9, 2003 | 01:01 AM
drift's Avatar
drift
Flaccid Member
maybe your fuel pump is dead or dying? it can maintain pressure at idle, but increased fuel load whle driving may be exacerbating it's inability to function properly
Old Apr 9, 2003 | 08:51 AM
preylude99's Avatar
preylude99
thats what it sounds like to me, fuel pump or something along the lines of a fuel problem. When it dies, is it just dying like you are turning it off or is it slowly dying and you notice a difference w/the engine? if its dying like you are turning it off it could be electrical.....
Old Apr 9, 2003 | 12:24 PM
matty1821's Avatar
matty1821
it smells like i am getting enough fuel, what electrical could it be?
Old Apr 9, 2003 | 01:40 PM
drift's Avatar
drift
Flaccid Member
this comment alone shows you're not accepting help.
check your fuel pump relay and ignition relay. usually if these are dead or malfunctioning, the car wont even start.
Old Apr 9, 2003 | 10:06 PM
matty1821's Avatar
matty1821
i always accept help, but i just seems like i am getting fuel, It started fine when the timing was changed and the engine was cold.
Old Apr 10, 2003 | 12:40 AM
drift's Avatar
drift
Flaccid Member
reread my first post.
if it was an electrical issue, it wouldnt even start. think about it.
