How much ZEX can i handle here?
Old Mar 29, 2003 | 07:27 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default How much ZEX can i handle here?
How much of a shot can i go with my mods? (posted in my profile) 35? or could i even go SAFELY at 55? and how much hp and faster times will 35 or 55 give me? i just wanna get nitrous and SAFELY drive my car without blowing it. thanks.
Old Mar 30, 2003 | 02:37 PM
ZiviCase10287
RacinMasonC
anyone?
Old Mar 30, 2003 | 03:59 PM
hlhiii's Avatar
hlhiii
zex comes with 55, 65, 75 shot increments. they average to the wheels is 40, 50, 60. i've seen dyno's that put down better and worse #'s. temperature and bottle pressure play a huge part. you can safely run the 55 shot with no upgrades other than colder plugs (i use NGK BKR7E). i would venture to say that with the 55 shot you hould pull anywhere from 1/2 to 3/4 of a second off of your time. the key is reading your plugs to make sure that the motor is not detonating. i've been spraying on my zex kit for almost 2 years without a problem.
Old Mar 30, 2003 | 04:07 PM
Teg711's Avatar
Teg711
Purge This...
i'm pretty sure there's a 35 shot too, should be okay with a 50 shot but if it were me on stock internals i'd just go with a 35...
Old Mar 31, 2003 | 02:25 PM
hlhiii's Avatar
hlhiii
zex only comes with jets for 55,65,75 shot increments. i've been running the 75 shot on my stock internals for almost 2 years. NX is the only company i know that the kit comes with a 35 shot.
Old Mar 31, 2003 | 03:31 PM
Teg711's Avatar
Teg711
Purge This...
oh maybe that's what i was thinking of
Old Mar 31, 2003 | 04:03 PM
ZiviCase10287
RacinMasonC
hiii, could i run 75 and be safe? or should i just go with 55 or 65 shot?
Old Apr 1, 2003 | 03:18 PM
drift's Avatar
drift
Flaccid Member
40% of stock horsepower or 50hp shot, whichever is lower with 91 octane.
93 or higher octane, you can safely run up to a 75 shot or 50% of your stock power, whichcever is less.
Old Apr 1, 2003 | 03:36 PM
hlhiii's Avatar
hlhiii
i didn't see your mods in your profile. i'm running a 75 shot on my b16 without problems at all. there are a few things that you should get (safety reasons) if you plan on running any higher than a 55 shot. higher flowing fuel pump, colder spark plugs, adjust timing on motor. i ran my set up for almost 2 years with a 255lph walbro fuel pump, NGK BKR7E plugs, and 2 degree retard in ignition timing (zex calls for 4 with the 75 shot but after reading the plugs numerous times 2 degrees was plenty). i bought the msd digital 6+ ignition so that when i flipped the n2o switch it would automatically retard timing. that way i wouldn't have to run on the street with less power due to timing retard. the ignition is awesome but not a necessity.
