For a higher redline you need the following....?
Old Mar 24, 2003 | 04:44 PM
szm426's Avatar
szm426
Default For a higher redline you need the following....?
new cams,retainers,springs and valves? am i missing anything? does Skunk2,crane and crower make good parts? does anyone have a higer redline(not type r engine b/c they already have 9k redline) thanks
Old Mar 24, 2003 | 04:46 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
why do you want one....not all engines need more room to rev....but yes, that seems like everything unless you need to remove the rev limiter
Old Mar 24, 2003 | 04:55 PM
szm426's Avatar
szm426
because ls motor redline is under 7k i think. and with higher lift cams, power gains are sean most at high rpm's
like 8-8.5k
Old Mar 24, 2003 | 04:58 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
then yes on all the parts, but make sure check the specs and the lift on the cam to make sure it will work with your new springs, etc....most of the time it isn't a problem because the springs can handle more lift than street cams have, but just make sure....too expensive to make a mistake
Old Mar 24, 2003 | 05:18 PM
szm426's Avatar
szm426
what brands would you recommend?
Old Mar 24, 2003 | 05:20 PM
qtiger's Avatar
qtiger
Rod bolts are also a good idea.
fizzbob7's Avatar
fizzbob7
90 accord h22a
skunk2 makes good ones.....i think spoon makes them....just any namebrand thats a big part of the market....i'm gonna get skunk when i do it though....JUN.....bunch of them
Old Mar 25, 2003 | 01:05 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Skunk 2 stage 2's are nice and create good power gains. With the spoons you wont see as much power increase, because they're not made to. And you cant go wrong with juns.
Old Mar 25, 2003 | 01:18 PM
Snoopy's Avatar
Snoopy
been there done that
correction itr does not have a 9k redline. they have a 8200? :thinking:
Old Mar 25, 2003 | 06:06 PM
hlhiii's Avatar
hlhiii
you'll also need to get the ecu done or get an already programmed one that will let you rev. the high.
