radiator ?
Old Jun 21, 2002 | 11:22 AM
maxrpm's Avatar
maxrpm
Default radiator ?
What causes your radiator to build up so much pressure that it blow up my radiator. IT now has a crack and im going to have to a new one after i waited 2 yrs to put the rebuilt engine in my teg.
Old Jun 21, 2002 | 02:00 PM
KawiGreenVTEC's Avatar
KawiGreenVTEC
My guess is this radiator isn't in a newer car, and that the radiator is starting to get old, and that's it, it's just old the honda/acura radiators as we all know have plastic end tanks, they crack over time.
Old Jun 21, 2002 | 03:31 PM
maxrpm's Avatar
maxrpm
well it was working fine before i did the engine swap.
the engine has 11:0:1, rods, port and polished heads.
the radiator is the ls.
because after i started the car it would have a idle problem and when i took it for a drive it would shut off when i step on the brakes.
any other ideaas or info would help. thanks
Old Jun 21, 2002 | 04:18 PM
KawiGreenVTEC
Honestly dude, not really a technical answer but....sh*t happens. things just break for no reason even though they woked fine the day before, but the radiator can't get so much pressure it would crack it, not for no reason anyway.
Old Jun 21, 2002 | 04:41 PM
maxrpm's Avatar
maxrpm
i wanted to know if its cause of the new engine or related to it. I haven't dyno it but was told with that setup(by the people who built it) would get around 210-250whp. wonder if this is too much power for the small radiator. thanks for your input.
Old Jun 22, 2002 | 06:50 AM
v4lu3s's Avatar
v4lu3s
honda radiators commonly crack over long periods of time. the plastic end tanks get brittle with age and heat and fail easily.
Old Jun 22, 2002 | 08:44 AM
KawiGreenVTEC
No it's not too much power, I was pushing over 200whp in my hybrid and I never changed out my Civic Radiator, the radiator just got old on ya.
Old Jun 22, 2002 | 06:49 PM
maxrpm's Avatar
maxrpm
this morning i used some super glue and those liquid metal sealant to fix the crack. i drove around town and haven't had any problems yet. I hope this will last until i have enough money for a fluidyne.
Old Jun 22, 2002 | 08:25 PM
Eddiebx's Avatar
Eddiebx
Hmm..if that crazy glue and crap doesn't hold, you should try some JB Weld, its an epoxy type glue, pretty strong stuff too.
Eddie
Old Jun 23, 2002 | 11:12 AM
KawiGreenVTEC
Eddie
I was just about to say this, I have fixed two radiators with JB weld, Not too sure how well that superglue will hold up.
