B16A Swap whats needed for my app...
Old Feb 9, 2003 | 10:11 PM
JDM-B18C-2KHB's Avatar
JDM-B18C-2KHB
Default B16A Swap whats needed for my app...
ok, heres the deal....
Droppin a 00' b16a in a 99' civic ex. what shift linkages will i need. can i use any integra linkage or does it have to be GSR? I know Si linkage will work, but i can easily get some teg LS linkage.
Also what mounts can i use from my car and what mounts do i need to get?
And lastly, i have the correct OBD2 ECU for the motor, but i heard i have to wire in a knock sensor or somthing like that? do i need to or will it just plug and play since i have the right ecu? the wire harness is the b16 wireharness its all attached to the motor.
thanks techies, feel free to give any other advice for this swap. its going down this weekend. thanks again guys.
Old Feb 10, 2003 | 11:33 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
That swap should be straight plug n play. You can use any B series linkage. You use B series mounts, except the driver side mount where you use your stock one, and an Si rear mount. The ECM will plug right in. The EX has a knock sensor, so you don't need to run any wires. If you have a P2T ECM, then it should plug right in. You may have to extend some plugs, but that should be the extent of your wiring needs.
Old Feb 11, 2003 | 08:41 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This is for a '92-'95, I'm not sure how much of the info is the same.
Old Feb 11, 2003 | 04:07 PM
Bubb_Rubb's Avatar
Bubb_Rubb
Wooo WOOOO
Any B series linkage except for a del sol...yes the teg linkage should work!
Old Feb 11, 2003 | 05:13 PM
AcuraFanatic's Avatar
AcuraFanatic
Yep, it'll pop right in. The joy of swaps.
Old Feb 11, 2003 | 10:06 PM
txek9's Avatar
txek9
you just got all the right answers for your question so swap that ***** in.
