GSR block
Old Feb 7, 2003 | 03:58 PM
whiteEJ8's Avatar
whiteEJ8
Default GSR block
Is $400 a good price for a bare GSR block with 65k on it? Thanks.
Colin
Old Feb 7, 2003 | 04:20 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If it's a longblock, that's a great price. If it's a shortblock, it's still pretty decent.
Old Feb 7, 2003 | 04:26 PM
whiteEJ8's Avatar
whiteEJ8
its a shortblock. Are there any tips you can give me so I'll know what to look for before buying it? I know where the engine code is but what type of damage should I look for?
Old Feb 7, 2003 | 06:51 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Since it's a longblock, look at the sleeves and make sure they're in good order. Look at the cylinder walls and make sure there's no gouges, etc. Rotate the crank and make sure it turns thru its full stroke. Ask questions about its history.
Old Feb 7, 2003 | 08:16 PM
drift's Avatar
drift
Flaccid Member
since you said "BARE SHORTBLOCK", check the cylinder sleeves for scarring and oil glazing. use a straight edge to check the deck for flatness. ensure no cracking of the cylinder jackets. inspect the bottom for deposits and oil coking, also checking all bearing surfaces for smoothness.
make sure the sleeves arent rusting. B series blocks use iron sleeves... if the rust is more than surface rust, cleaning it off will cause pitting which will reduce oil ring sealing ability.
and since it's a bare block, get him down more towards $300... i have bought many fully loaded shortblocks for $400 or less.
Old Feb 8, 2003 | 07:36 AM
whiteEJ8's Avatar
whiteEJ8
Thanks for the help guys.
