Ecu ??
Old Jun 18, 2002 | 09:32 PM
Bl@ck's Avatar
Bl@ck
Sinner
Default Ecu ??
which ODB II ECU is best for a hondata stage 2. they haven't decoded the ECU for 96-01 accords. i've heard that i can use the ECU from a teg. is this true?
Old Jun 18, 2002 | 10:43 PM
qtiger's Avatar
qtiger
No OBDII ecu can be Hondata stage 2, 3, or 4 chipped.
Old Jun 19, 2002 | 01:34 AM
Bl@ck's Avatar
Bl@ck
Sinner
ok... how about stage 1?
Old Jun 19, 2002 | 01:47 AM
jdmcrx89's Avatar
jdmcrx89
www.teamrush.net
you have to convert to obd1, then you can use the teg ecu
Old Jun 19, 2002 | 02:29 AM
Bl@ck's Avatar
Bl@ck
Sinner
how do i do the conversion? what ECU would work best if i did the conversion?
Old Jun 19, 2002 | 03:24 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
OBD II is one of the reasons AEM came out with their EMS.
To convert to OBD I to use hondata, you need to re-wire the car's engine, using only what OBD I can use, namely a single O2 sensor, knock sensor, etc; and anything that isn't used in OBD II, doesn't get hooked back up. A few companies make retro conversion harnesses I believe, though I didn't seem to have a lot of luck with the Skunk harness I had a hand in, but admit that was both an OBD retro job, and a swap.
-Harry
AIM: NDcissive
vinalfingas
May 1, 2003 10:26 AM
doodoobrown
Prelude
Apr 20, 2003 10:13 PM
fastludeh22
Nov 7, 2002 07:07 AM
jermothedrunk
Oct 30, 2002 09:53 PM
chameleon
Jul 9, 2002 09:00 PM
