ECU applications?
Old Jan 3, 2003 | 10:48 AM
drdavidge's Avatar
drdavidge
Default ECU applications?
does anyone have a listing on every type of honda/acura ECU and a list of what types/years of car that each of them will work with and fit into?
Old Jan 3, 2003 | 10:58 AM
qtiger's Avatar
qtiger
http://www.hondata.com/ecus.html
Best I can do. Civics and Integras OBD0-OBD1.
Old Jan 3, 2003 | 10:59 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Here's a start:
http://hondata.com/ecus.html
Those are all OBD-I Honda ECMs that are compatible with Hondata. You generally don't see many modifications for OBD-II and up ECMs. Also, ECMs for similar engines will basically interchange, but you need to match the OBD generation of your car and/or harness. If you're trying to run an OBD-I ECM in an OBD-II car, you would need an adapter harness.
Old Jan 3, 2003 | 11:02 AM
qtiger's Avatar
qtiger
Originally posted by inspyral
Here's a start:
Those are all OBD-I Honda ECMs that are compatible with Hondata. You generally don't see many modifications for OBD-II and up ECMs. Also, ECMs for similar engines will basically interchange, but you need to match the OBD generation of your car and/or harness. If you're trying to run an OBD-I ECM in a OBD-II car, you would need an adapter harness.
:chuckles:
Old Jan 3, 2003 | 11:03 AM
drdavidge's Avatar
drdavidge
wow, 2 replies within 1 minute of each other that give me the same site, lol. thanks for the start. keep the information comming =)
Old Jan 3, 2003 | 11:04 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Originally posted by qtiger
:chuckles:
h: :doh:
Old Jan 3, 2003 | 06:01 PM
VtecApprentice's Avatar
VtecApprentice
Issit possible and expensive to convert an OBD ? ? example OBG 2 to OBD 0 ? ? ? from what is know its like the earlier generate has less restriction on modding correct ? ? ? ? ?
Old Jan 3, 2003 | 10:16 PM
Snoopy's Avatar
Snoopy
been there done that
you can convert from obd2 to obd1.
Old Jan 4, 2003 | 05:43 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You can rewire any car to any other sort of wiring if you really want to. That the earlier generations "restrict modding" in any way is mostly an urban myth. Generally the only reason to convert an OBD-2 car to OBD-1 is so you can run a Hondata or some other kind of chipped ECU.
