How do you like this turbo setup
Old Jan 3, 2003 | 08:27 AM
Dave C's Avatar
Dave C
Default How do you like this turbo setup
http://www.honda-tech.com/zerothread?id=369711
Apologies in advance if this was posted previously. This old man has a hard time keeping up with all you young guys.
Old Jan 3, 2003 | 08:39 AM
Snoopy's Avatar
Snoopy
been there done that
nice looking manifold
Old Jan 3, 2003 | 09:02 AM
qtiger's Avatar
qtiger
HyTech knows what they are doing, plain and simple.
I like the dump tube coming off the wastegate... you should call them and ask if it is CARB legal. :chuckles:
Old Jan 3, 2003 | 10:23 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I like the water-air i/c
Old Jan 3, 2003 | 11:22 AM
jdblack1's Avatar
jdblack1
Mine didn't cost as much as the manifold
Old Jan 3, 2003 | 01:05 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I'm not a fan of water-air IC's because of my predilection towards road racing.
Old Jan 16, 2003 | 05:43 PM
LT's Avatar
LT
The deer had to die!
ellaborate Mike...i'm really interested in this kit and want to know what you mean.
Old Jan 16, 2003 | 06:45 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
He doesn't like air/water I/C because of the way they operate. They're great for short 1/4 blasts, and usually work just as well under normal driving as air-air I/C's....The thing about air-water I/C's is that you need a resevior(sp) of water, a pump, transfer lines, and way to cool the water(extra radiator).......All that equipment adds up to a good amount of extra weight and also the space requiements. On the upside there is no need for a FMIC. So the stealth aspect is pretty good.
With air-water I/C you can cool the intake charge to below ambient outside temps. If it's 100 degree's outside and you're running 50 degree water past the I/C you're gonna be able to cool the intake charge to below outside ambient temps.... which isn't possible with air-air. With air-air I/C the best you can do is cool you intake charge to how hot the air is outside. So if it's 100 degrees outside that's as low as your intake temp is gonna be.
Also a neat trick with air/water I/C's is adding ice into your resevior to get an ultra cool water supply... The plus being that you could get your intake temps down to near freezing. Good for power! Downside is that it won't stay that way for long, so it's good for the 1/4 mile track.
Now in a perfect world you'd be able to keep the water down to below ambient temperatures at all times. But in stand still traffic, high heat, or hard high RPM driving, the water in the system will begin to heat up. After a certian amount of time the water will heat soak, and then you're cycling nothing but hot water past the I/C.
Well......thats a few reasons at least....I may be wrong though
Old Jan 17, 2003 | 04:13 AM
LT's Avatar
LT
wowzers!! thanks!! that was very informative and helpful. i can see now, but that system really requires a water-air cooling system. id still use it.
