P28 or p72 ecu?
Old Jan 1, 2003 | 08:48 PM
shonnys92si's Avatar
shonnys92si
Default P28 or p72 ecu?
i have a 92 si with a 94 jdm gsr (b18c).im throwing a code 23 , which is my knock sensor. i wanted to know if i could use my old p28 ecu if i chipped it. would i have to change my intake manifold, or would it be better to use the p72 ecu and re-wire my knock sensor. ur help would be much appreciated. thanx
Old Jan 2, 2003 | 03:42 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Which ECM are you using now? I assume you're using the P72 now, since you're not having any issues with the secondary intake runners. I would just run the wire for the knock sensor.
Old Jan 2, 2003 | 09:24 AM
dubcac's Avatar
dubcac
I
If you used the p28, it would not control the secondaries, so you'd need the skunk2 manifold, or the JG manifold. But I'm with Inspyral, just wire the knock sensor.
Old Jan 2, 2003 | 10:00 PM
shonnys92si
is it hard to wire the knock sensor, i complete 4got about that , when i was doing my swap. i also kinda know were the knock sensor is , but i can't see it. where is it easier to see it from , the top of the engine or going under the car. thanx
Old Jan 2, 2003 | 11:55 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The knock sensor is on the back of the block, so the intake manifold would probably be in the way if you were looking from the top. Did you get a harness with your swap? If so, look for the knock sensor plug and use it to run wire(s) to the ECM plug.
Old Jan 3, 2003 | 06:30 PM
shonnys92si
yeah it came with it ,what color is it and how does it look.
Old Jan 3, 2003 | 07:57 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
That's what the knock sensor looks like. The plug is round and looks kinda like a TPS, IACV, MAP sensor plug. Since you'll be extending it to the ECM anyway, it doesn't matter which plug you take off the JDM harness, as long as it fits onto the knock sensor. I'm sure there'll be more than one plug on the JDM harness that'll work. Just snip it off, and ad some wire to it to extend it to your ECM plug. You would need to know the pinouts for your ECM in order to know where to add the wire(s) once you've extended it to the ECM plug.
Old Jan 5, 2003 | 01:30 AM
shonnys92si
cool that pic and explanation helped alot, where can i get the pinouts. thanx
Old Jan 5, 2003 | 01:31 AM
shonnys92si
doi need to take the manifold off to run the wire, like in that pic.
