what exactly does the cap & rotor do?
Old Dec 17, 2002 | 12:16 PM
exzeltus's Avatar
exzeltus
Default what exactly does the cap & rotor do?
Like the ? asks.
I'm not sure what is what and what they do for your car.
Let's keep flaming to a minimum.
Old Dec 17, 2002 | 02:36 PM
sunshine's Avatar
sunshine
Torqueless Wonder
The rotor is a little metal piece that spins inside the distributor. In the distributor assembly there are 4 contacts. Each contact coresponds to a cylinder. When the rotor makes contact with er.... the contact on distributor the corresponding sparkplug goes off. Something like that. The cap just goes over the distributor assembly.
Old Dec 17, 2002 | 02:40 PM
Snoopy's Avatar
Snoopy
been there done that
http://www.howstuffworks.com/ignition-system.htm
read and learn
Old Dec 17, 2002 | 03:33 PM
exzeltus's Avatar
exzeltus
totally forgot about that site, thanx.
Old Dec 17, 2002 | 08:10 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Originally posted by sunshine
...When the rotor makes contact...
It doesn't actually make contact, it arcs across.
Old Dec 17, 2002 | 10:37 PM
VTECseoul's Avatar
VTECseoul
i love my wife's (y)
When the rotor makes contact with er...the contact on distributor the corresponding
...makes contact w/ the POINTS on the distributor...
& the cap acts like a shield protecting the contacts & points from getting wet, as well as a connection for the spark plugs/wires & keeps the firing order.
Old Dec 18, 2002 | 05:11 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Car manufacturers haven't used a points breaker system in a distributor in a long time. As Gasoline fumes said, the rotor doesn't actually make contact with the posts in the cap, it arcs across, but due to the heat generated the posts erode after a while, and carbon arcing begins to occur, which is when you need to start looking into replacing both the cap and the rotor.
The cap's primary function is to keep the posts in the same relative location to the the distributor body, nothing more. As for keeping the inside dry, and free of dirt, that is a secondary function manufacturers started using to their advantage when the began to realize how much havok dirt can play with spark. But again, Cars haven't used a point breaker system in the distributor since the 70's.
-Harry
AIM: NDcissive
Old Dec 18, 2002 | 01:03 PM
exzeltus's Avatar
exzeltus
Thanx guys.
