adjusting fuel pressure
would anyone know how to adjust fuel pressure? im looking to gain 30% over stock. worst case scenario i would have to replace injectors and possibly pistons, but i am tearing it down this spring anyways and building bottom to top. im just testing the waters...any other bolt-on suggestions besides turbo and nitrous? after the build im going turbo.....thanks guys!!
Upping fuel pressure is usually a bad Idea to try and get more fuel into the engine. The injectors will have a harder time opening and may even deliver less fuel than the injector at stock fuel pressure setting.
The rite thing to do is go bigger injector and tune. I wrote this thing if you want to take a look. http://www.talkjdm.com/showthread.ph...927#post115927 To fudge injector size go to. http://www.rceng.com/technical.aspx?...lsYKf6AqOSn6OJ :woohoo: Any way if you want to raise fuel pressure get an fmu or adjustable fuel pressure regulator. |
