D16Y7/Y8 VTEC Swap- Wiring Questions?
Old 09-29-2008, 05:05 PM
Fuse
Fuse's Avatar
The only option you have it to wire in a knock sensor. Its one wire. Or convert to obd1.
Fuse is offline
Old 09-29-2008, 06:41 PM
97d16vtec
Ok, so it'll pretty much just be like the vtec components and IACV. Just find a knock sensor from the vtec engine and wire it into the ecu.. I think my only problem that might come up with that is that I think the knock sensor mounts in the engine block and apparently my block didn't come with one, so i'll have to figure out where to mount it.
97d16vtec is offline
Old 09-29-2008, 07:04 PM
Fuse
Fuse's Avatar
Keep it away from the head or it may pick up valve train noise and retard your ignition timing. This is bad for power.
Fuse is offline
Old 11-10-2016, 08:46 PM
Braxton845
Default P29 ecu
If I use a stock p28 do I still need to use a knock sensor?
Braxton845 is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
