engine revs up and down--help
Old Sep 20, 2008 | 08:34 PM
jrairman's Avatar
jrairman
Default engine revs up and down--help
i just changed my stock intake on a honda civic 1.6 to an aftermarket racing hi volume intake....i believe all vacuum connections are good....engine revs up and down between 1200-1700rpm every 2-3 seconds at idle....what could be the cause?
Old Sep 22, 2008 | 10:28 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Can you give a little more info? Like what type of engine and such..Did you try to re-install the stock one again to see if it still does it?
Also, what brand of intake?
Old Oct 7, 2008 | 08:11 PM
ifiwasmeso's Avatar
ifiwasmeso
F.I.T.V.= fast idle thermal valve.
Old Oct 8, 2008 | 07:35 PM
gsr converters's Avatar
gsr converters
this was the problem for me.
or maybe try the I.A.C.V.
Old Jan 18, 2009 | 06:43 AM
s2henderson's Avatar
s2henderson
Default Odyssey revving up and down...
My 01 odyssey began surging in park and neutral between 1000 and 2000 rpm. check engine light came on, TCS would not go off after warm. Map Sensor fixed it for me.
Old Jan 24, 2009 | 11:14 AM
DXCRX1989's Avatar
DXCRX1989
check ur idle air control valve
Old Jan 26, 2009 | 06:09 AM
s2henderson
Default Not so fast...
My odyssey has just been put back in the shop with the same problem again! The new map sensor did not fix the problem... we'll see what they say. Is the consensus the F.I.T.V. or the Idle air control valve?
Old Jan 27, 2009 | 03:31 PM
ragecage92si's Avatar
ragecage92si
Iac
Old Feb 2, 2009 | 05:50 AM
s2henderson
Default Not the Map sensor
I posted the Map sensor for the 01 Odyssey, it did not fix it , it was the FITV. The codes pulled were indicating map sensor, had to go back and install the FITV.
