Turbo on B17a or B18a What do I need?
Old Nov 28, 2002 | 09:15 PM
pimpingacura's Avatar
pimpingacura
Default Turbo on B17a or B18a What do I need?
Okay I don't want a kit because I have a turbo and a manifold. I know I need a intercooler or I don't but I am going to put one on. I am basically asking what size injectors and how much fuel pressure and where do the one way check valves go? Thanks in advance
Old Nov 29, 2002 | 06:56 AM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Ummm, what car? Are you looking to run a FMU, 450cc/AFC hack, or Standalone?
Also, you'll prolly want a BOV, some I/C piping, a Wastegate...just to start with.
Old Nov 29, 2002 | 07:26 AM
pimpingacura
Okay basically this is just to go for 10lbs of boost so I want to use pretty much the stock setup with as few other things as possible because I am on a budget sorta. I am not going to run it until I have all I need but I am asking for a integra engine what do I need? I know I need intercooler piping that is the easypart and I have wastegate and will get a bov but as far as what size injectors and fuel pressure and where do I put the one way check valve so the map sensor doesn't see boost?
Old Nov 29, 2002 | 08:19 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You can run 10lbs of boost on stock injectors with a 12:1 FMU and inline pump, but it'd be better to run some DSM 450s with an AFC, or even better to run a standalone unit. Checl valves are typically put between the throttle body and the MAP sensor with an FMU setup. You either piece together some tees and sections of vac hose for the fish tank type valves, or screw an aluminum check valve in between the tb and MAP sensor. A check valve is not needed for a 450/AFC setup up to 10-12lbs of boost, nor is it required for a standalone unit.
