teg drinking gas
Old Nov 27, 2002 | 09:57 AM
phiset's Avatar
phiset
Default teg drinking gas
my 94 teg LS drinks gas now that is is cold outside, i am getting a 30% reduction in fuel economy, i had the same problem last year & changing the air filter did not really help
Old Nov 27, 2002 | 08:50 PM
More&Faster's Avatar
More&Faster
well if most of your driving is done when the engine is cold, like if you only make really short trips, then the cold can seriously affect your fuel economy.
Old Nov 28, 2002 | 05:39 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
When it's cold your car will run more lean. Just start shifting at 3k rpms.
Old Nov 28, 2002 | 06:50 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Lean means less gas. He wouldn't be loosing fuel economy if his car was running lean.
Old Nov 29, 2002 | 03:01 PM
pimpingacura's Avatar
pimpingacura
Are your spark plugs good? Has your fuel filter been changed lately? What about your tire pressure the cold affects that. Just some ideas
Old Nov 29, 2002 | 08:51 PM
b00gers's Avatar
b00gers
are you sure its because of the cold? have you been up to date with tuneups and regular maintainence?
Old Nov 30, 2002 | 04:35 PM
phiset's Avatar
phiset
i changed the plugs over the summer, i wonder if it is a fuel pump or fuel filter problem cause i don't think those have ever been changed
Old Dec 2, 2002 | 04:18 PM
SPORTIMAGE's Avatar
SPORTIMAGE
Get a feul pressure regulator and a air feul ratio guage. When it gets cold outside you will have to adjust your feul pressure. Its just like running at the track you have to tune your car for the conditions.
Old Dec 2, 2002 | 06:00 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
When the engine is cold it runs a lot more rich, and it's not running efficiently until it's warm. If you're making trips that only let the engine get up to temp as you arive at your destination, that explains your mileage problems completely.
Old Dec 2, 2002 | 07:05 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
A/F ratio guages read the voltage off the stock oxygen sensor. Data from the sensor is only used by the ECU when it is in open-loop mode. It switches over to open-loop at something like 74 percent or greater TPS and some RPM. Out of that range the voltage reading from the sensor jumps all over the place, which is totally inaccurate. Unless you have a wide-band oxygen sensor, any a/f guage is more of an "oh crap I'm leaning out" warning light on WOT runs than a tuning tool. Secondly, a fuel pressure regulator can only bump the whole fuel curve up or down a bit. It's not a very precise method of adjustment. The best way to tune is to get at the fuel and ignition maps inside of the ECU.
The most probable reason the car eats gas when it's cold out is the weather. Cold air is more dense which means more oxygen. The engine can then use more fuel to burn that extra oxygen, hence the higher gas consumption.
