OBD1 and OBD2???
Old Nov 20, 2002 | 11:48 AM
EKHatchRacer's Avatar
EKHatchRacer
Default OBD1 and OBD2???
this might be a stupid question but what is OBD1 and OBD 2? what are the differences and are there any advantages one has over the other?
Old Nov 20, 2002 | 12:52 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
On Board Diagnostics Version 1
On Board Diagnostics Version 2
Basically they're government mandated forms of emission controls integrated into the ECU. All 92-95 Hondas are OBD-1, all 96-up are OBD-2. OBD-1 are more easily modified (i.e. chipping, etc) and as far as their adaptiveness are a bit more forgiving of stuff like advanced timing. The OBD-2 ECUs will figure out you've spun your distributor and will retard the timing enough to get rid of the advance you dialed in which is kind of a pain.
The typical statement you'll hear is "OBD-1 is better for mods than OBD-2 because uh..."
Old Nov 21, 2002 | 12:06 PM
EKHatchRacer
when you say 92-95 hondas and 96+ is that all hondas or just civics?
Old Nov 21, 2002 | 01:48 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
All, to my knowledge. That includes Civics, Integras, Preludes...
Old Nov 21, 2002 | 02:37 PM
SmOkIneLf's Avatar
SmOkIneLf
so it would be good to get a OBD-1
Old Nov 21, 2002 | 05:32 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
It doesn't really matter much. I wouldn't bother if you're just gonna run a stock ECU or something...
Old Nov 23, 2002 | 02:58 PM
EKHatchRacer
but if you are gonna mod the ECU then OBD-1 is better because it is easier to mod?
Old Nov 23, 2002 | 05:40 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Nobody really chips the OBD2 ECUs. Chips are useless though, get a Hondata s100 for $245 and have it tuned on the dyno. That's on top of the cost of getting an OBD1 computer and assorted wiring, but you'll have to do that no matter what if you have an OBD2 car. Otherwise you can get the AEM EMS which is available in plug-n-play with the OBD2 wiring.
The ability to get easy horsepower out of an ECU chip is a total myth. You'll get a little better throttle response and maybe a couple more horses but nothing major. You make power by getting a good air-fuel mixture for your particular setup which is undoubtedly different that whatever car the company selling the chip used to make their program. These "Mugen" programs (which most likely were pirated) for example, were originally designed for their Formula 4 motor. It has insane cams, a 9500 RPM rev limiter, 13:1 CR, individual throttle bodies, etc etc etc. Not to mention that with the program, many sensors are disabled (they're not there on the race cars) and for the most part you can't even get the thing to throw a code when something's wrong. Regardless of the fuel tuning, you wouldn't want to run that program on a street-driven car.
