VX engine into CX chassis
Old Jun 2, 2008 | 10:29 AM
livelyjay's Avatar
livelyjay
Default VX engine into CX chassis
Local guy is selling a CX shell, all it's missing is an engine and tranny. Since this is going to be my commuter car, I am looking into dropping the VX engine into it. I've found some at local yards, but I read in another post that the wiring harnesses are different because of the O2 sensor for the original VX.
Should I scrap the idea of the VX engine and just get the CX?
If I went with the VX, would I need the wiring harness from the VX donor car as well, or is there a way to hack the stock CX harness so it will work with the VX ECU?
Old Jun 2, 2008 | 01:00 PM
tobitvx's Avatar
tobitvx
call rywire and go with the vx
Old Jun 2, 2008 | 01:32 PM
livelyjay's Avatar
livelyjay
It all depends on cost versus ease. I've never done an engine install before, so the replacement CX motor wins there. I found a "local" yard with a CX engine and tranny for $950 (only 55k on it, but no alternator, starter, etc) and another has an engine for $400 (minus distributor and likely no alternator, starter, etc) and another has a tranny for $350. I haven't been able to find a VX wiring harness, nor have I found any information about wiring up the VX to a CX engine harness. So far the D15B8 is winning the argument.
Old Jun 4, 2008 | 02:56 PM
5genhb's Avatar
5genhb
I'm no expert or "guru" here, but why go the VX route? When they were available, the Civic VX had one of the WORST reps for being a pointless car. That is, not a huge savings in fuel, but a very poor drive as Civics go. The VX into a CX shell would be somewhat similar to installing a VTEC engine in a non-VTEC shell as the VX is somewhat of a VTEC engine...sort of early I-VTEC?
If you want fuel economy, stick with the CX/DX engine (you don't say what year CX, and after '95 the CX was just a stripped DX). I had a '92 CX and my Honda mechanic said the CX's engine had some design flaw (I never got him pinned down on this point) that made them less long-lived than the '92 DX engine. I went with a non-VTEC Integra engine in mine after it seemed to start drinking oil in large amounts and the fuel economy stayed the same or improved somewhat (tho I did have it modded with a CAI and a header/free-flow cat-back exhaust).
