Fluidyne Integra Radiator in a Civic?
Old Oct 18, 2002 | 07:46 AM
jwaked's Avatar
jwaked
Default Fluidyne Integra Radiator in a Civic?
I have a 92 CX Civic with a 95 GSR engine and A/C. Can I fit a Fluidyne radiator that is made for the Integra. How about if I remove the A/C?
Thanks
Jay
Old Oct 18, 2002 | 08:09 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
people make small brakcets to help hold up the longer integra radiator in civic's.
you can make them yourself, but i believe del sol vtec radiators bolt right in.
i'm not exactly sure on this.
if you ditch the ac you can just get the fluidyne made for the civic which is half the size of the integra radiator it'll be fine for cooling purposes.
Project EVA - The Track Package
Project EVA
Old Oct 18, 2002 | 08:34 AM
jwaked's Avatar
jwaked
The car will be used for Road Racing and the temperature here is very hot. Thats why I want the best possible.
Thanks
Jay
Old Oct 18, 2002 | 09:03 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
If you want to install the Integra radiator, you will most likely have to remove A/C condensor. With a road racing car, that probably won't be a big issue though. You will also have to modify the lower mounts for the raditor. You can simply use the far left mount and simply attach a piece of steel to the bottom of the frame rail for the other side of the radiator and fabricate a top brace or cut the other mount off and re-weld it on the other side.
I know of people installing the normal OE Integra radiator in '92-'95 Civic's and I've heard of people using the Integra Fluidyne there too. You may have some clearance issues with the driver side fan and the exhaust manifold, but everything should fit. Seeya.
Old Oct 24, 2002 | 04:31 AM
Burke's Avatar
Burke
i fixed up a gsr rad to fit my civic. had to make my own brakets though. i used the civic fan and it comes pretty close to my 4-1, but its still good. keeps her real nice and cool. i dont think my fan has ever had to come on yet
ps - gsr rad $135 fluidyne $300+
later
Old Mar 6, 2006 | 07:05 PM
vc eg's Avatar
vc eg
Will I need a Denso or Showa Type koyo Integra Radiator for my gsr in 92eg ?
Old Mar 6, 2006 | 07:57 PM
vc eg's Avatar
vc eg
Anybody?
