97 3.5 rl no start
Old Jan 10, 2008 | 03:56 AM
fenkell's Avatar
fenkell
Default 97 3.5 rl no start
has fire no fuel ,turns over,new pump?
Old Jan 10, 2008 | 04:23 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Check the obvious things first, is the fuel pump priming when you turn on the ignition? if not have you checked all the fuses? is everything plugged in ok? (fuel pump plug connectors, injectors etc?
Also check for leaks, start from the pump and follow it up to the injectors, checking for leaks.....it may be a leaking connection at the fuel rail, fuel filter or even at the fuel pressure regulator.
I presume it isnt a immobliser problem? have u checked this?
Old Jan 10, 2008 | 04:31 AM
fenkell's Avatar
fenkell
no power to pump?dosn`t seem to be an immobliser.
fuse ok power at fuse
Old Jan 10, 2008 | 04:48 AM
B16a2VTIguy
Built B16a
NO power to pump? how did u check this?
does it prime when turn on the ignition?
If its not getting power to the pump, follow the wiring up to the fuse panel see if ther are any brakes or damage to the cable up to ther. Pay close attention to any 'foriegn' wiring.
Has the car got a aftermarket immobiliser fitted?
Old Jan 10, 2008 | 12:45 PM
fenkell's Avatar
fenkell
relay for fuel pump was the fix
